Results 11 to 20 of 27
Thread: Where do Perth people go to get their wheels aligned/balanced?
  1. #11
    Senior Member vivioman's Avatar
    Vernon
    Aveley
    yes exactly...and also those people who tell you it can't be done.
    those are the people/businesses that I want to avoid.
  2. #12
    Senior Member Moebius's Avatar
    Christian
    Wheels World did a pretty good job on my ae92, from memory a wheel alignment was 70 or 80 bucks.
  3. #13
    Senior Member FLCL's Avatar
    Kev
    lol yer i work there so free alignments for me.
    but case in point is if you insist you want certain settings then you either get them or the aligner tells you he got as close as he could to your spec but ran out of adjustment travel.
    I had a s13 where i wanted -1 camber on the rears. Wheelsworld adjusted the stock bolt adjustment but was only able to get as low as -1.3 on one side so he evened it out and told me. I was still content at the work.
  4. #14
    I go to the tyre shop. They do it all.
  5. #15
    Vernon
    Aveley
    Does anyone know of any shop in WA that does on car wheel balancing?
    i.e. the wheels are not taken off the car but a machine is used to balanced the wheels while they are on the car.
  6. #16
    Senior Member Johnny_K's Avatar
    kiara
    never heard of that before lol , just get you wheels balanced like any normal car. At my work we have a tire shop (barbagallo tire service) do my wheel alignments, i use to have to take my front bumper off to get it on the hoist but now they've installed longer ramps as ferraris/lambos also had probs getting onto the hoist
  7. #17
    Vernon
    Aveley
    yeah apparently bob jane do provide on car wheel balancing service...might give them a call...
  8. #18
    Aaron
    yeah i used to do on car balncing at city motors when i worked there. i wouldnt recommend it as there are too many other things like in your suspension that can throw it out of wack.
    not only that there arent many people that ever get it right. it is pretty tricky
  9. #19
    Vernon
    Aveley
    I actually thought that on car balance would improve the balancing?
  10. #20
    Aaron
    in theory it should but in reality it doesn't
    for instance say your wheel bearings are slightly out,you will never be able to balance your wheels to suit the play in your bearings. you will only magnitude the problem not to mention you will never get the balance of the tyre right
    for oncar balance your suspension and steering have to be spot on otherwise it will never be right.
    the other problem is the way in which you balance oncar. the machine is just a roller that you press against the wheel. if your not consistant with the speed and force that you press against the wheel you get a different result. theres just too much room for human error
    these are the main reasons why noone bothers with oncar anymore.
  1. Free ae86 stuff for Perth people
    By Tom86 in forum Perth & WA Events and Discussion
    Last Post: 11th October 2010, 03:21 AM
  2. Tyres fitted and balanced Melb S.E?
    By Jase86 in forum Melbourne & Vic Events and Discussion
    Last Post: 12th July 2009, 01:52 AM
  3. Replies: 3
    Last Post: 12th August 2007, 12:40 PM
