Results 1 to 5 of 5
Thread: What would cause Ae86 Heaters to stop working ?
    kravit
    bowen hills
    Hey guys,
    When i did my conversation from ae86 jdm halfcut in sprinter my heater worked for few mins and next time i turned on the car it stoped working all together ?? anyone have any ideas,its winter time and bloody cold in my car
    Jul 2009
    blocked? tap broken? check if the tap (copper Y peice) is opening and closeing..
    did you flush your system? it could be blocked up enough to not get very hot at all.. try using some of that radiator flush... just follow the directions on it..
    Apr 2005
    you turn it on and nothing happens? blown fuse?
    or does it just not blow hot?
    Grant.
    Elite rthy's Avatar
    Leo
    Tulla
    yea if the fan doesnt work it would be a fuse, but if its not blowing hot/warm air once the engine is warm it would be a block somewhere
    Rob
    Moorabbin
    its quite likely that the half cut was sitting around for ages and might have a build up of crud inside the coolant jacket. It probably got lodged in your heater or something. Give it a a good flush out and get a fitting to attach to the heater lines and give them a reverse flush.
    Other things that it could be are fuse as mentioned(if its actually the fan not working), or the tap that is operated by cable from inside the cabin. When I got my last 86 this cable was bent at the end and didn't open the heater valve so I replaced it with on I had lying around and it worked fine after that
  1. Replies: 21
    Last Post: 28th July 2012, 10:49 PM
  2. AE86 cluster light not working
    By LEVIN86 in forum Technical - Questions
    Last Post: 31st March 2011, 09:09 AM
  3. AE86 Dash not working...
    By Skid Kid in forum Technical - Questions
    Last Post: 25th January 2009, 10:18 AM
  4. How to get ae86 tacho working with 4agze
    By sprinkler86 in forum Technical - Articles
    Last Post: 30th April 2007, 12:14 AM
  5. too much drift makes your indicators stop working. wtf?
    By keiichi in forum Technical - Questions
    Last Post: 8th October 2006, 05:33 PM
