first problem i have is with the fuel pump relay, does anyone know which wires are which - I know the BR is ignition 12v, 2 wires are from the AFM as labeled in pic, (dont know why but guessing theyre safety related ie no air flow, pump stops pumping) which leaves WB wire and B (& silver diamonds). anyone know which is which?
also the blue afm wire is joined at the relay to another one as can be seen but has been cut - what do i use this for (if anything)the 12v also has 2 wires but these are traceable so all good
2nd is the starter relay, one of the wires BW comes from computer, W is 12V constant, B goes to starter, and WR is constant. question is, i think the starter solenoid is engaged by the computer so how does the computer know when key switches to start? Since this requires more wiring, can i just get rid of this setup altogether, run the ke70 starter relay and avoid lots of mucking around or does the computer have to start the starter?
thanks
