Results 1 to 5 of 5
Thread: 4agze engine conversion
    Oldschool Member
    Jan 2006
    hi guys,
    probley shouldn't have started a new topic but, i did
    I was just wondering if the loom for a 4age in an 86 can be used when converting the engine to gze?
    if not, what is needed? any info on this conversion would help.
    thanks guys
    Ferny Grove
    you would have to use a 4agze loom
    Yes and no. It will definitely not be an unplug GE ECU and plug in GZE ECU and start driving affair.
    The ECU plugs will be different, there are a few things different between the engines (eg idle control, SC relay) and a few things in different places (eg TPS).
    However you could conceivably butcher your old GE loom and splice it into the plugs on the GZE computer and add the few wires needed.
    I think you would be way better off pulling the loom out and starting from scratch. You'll end up with a proper job and find it very educational.
    Oldschool Member
    Jan 2006
    thanks dude
    see sam his the guru on this sort of thing
  1. CAN 4AGZE ECU RUN ANY 4AGZE ENGINE?
    By HYPNTK in forum Technical - Questions
    Last Post: 8th November 2006, 11:20 PM
  2. 4agze conversion
    By buster86 in forum General Topics (No Technical Questions)
    Last Post: 19th August 2006, 06:08 PM
