Results 1 to 9 of 9
Thread: 20v exhaust flange
    Oldschool Member
    Jan 2006
    hi guys,
    im just wondering if any of you guys know if the 20v exhaust pattern is the same as the 16v? in other words, will a turbo manifold for a 20v bolt to the 16v head?
    thanks guys
    Oldschool Member
    Jan 2006
    does any one know??
    Will
    search
    Oldschool Member
    Jan 2006
    thats plan 2. what can i say, im a lazy barsted
    Andrew
    East Melbourne
    the ports are the same, but the bolt pattern is not the same. the 20v has one bolt offset from the 16v (closest to the firewall in a 86). you should just be able to re-drill the hole to make it fit.
    edit:
    hehe just beat me!
    Veteran slide86's Avatar
    Huw
    Hills
    16v and 20v dont share the same stud pattern. they are close but not the same. you can modify a manifold to suit either tho.
    requires the drilling of extra holes
    Oldschool Member
    Jan 2006
    thanks fella's
    Elite rthy's Avatar
    Leo
    Tulla
    the two outer holes are different, I can redrill it for you for $10
    Oldschool Member
    Jan 2006
    thanks dude, i should be capable.......also it probably wouldn't be worth it as im in the NT
  1. Exhaust Flange Gaskets Alternative
    By Patrini in forum Technical - Questions
    Last Post: 15th May 2011, 02:07 AM
  2. exhaust manifold flange design
    By Skylar in forum Technical - Questions
    Last Post: 8th September 2010, 01:13 PM
  3. exhaust flange
    By fozz in forum Cars or Parts Wanted
    Last Post: 23rd January 2008, 03:42 PM
  4. Bigport exhaust flange
    By Robo86 in forum General Topics (No Technical Questions)
    Last Post: 18th December 2007, 01:35 AM
  5. exhaust flange for JDM manifold
    By haydenzz in forum Technical - Questions
    Last Post: 6th December 2007, 11:53 AM
