Results 1 to 5 of 5
Thread: welding inner guard to outer
    Jason
    Gold Coast
    To flare my rear guards the inner guard needed to be cut away from the outer to alow the metal to bend, (those who have flardd rears before know what im on about).
    anyway the guy that did it for me went a bit over board with the cutting, now i have 2 large, long holes that need to be filled.
    instead of welding peices in he told me to fibre glass the holes up, (impossible)
    his reason for not wanting to weld on to the outer guard was that it would warp it.
    has anyone welded to the outer skin of the car? and did it warp the metal badly?
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    I just finished doing rust repairs on my left rear quarter around the window.
    Yes the metal warped but that is to be expected when metal is heated it expands
    when it cools it contracts. This is what causes warpage. Who ever flared your guards
    should have done this before they finished them when it would be easily repaired
    with a hammer and dolly and a little more bog.
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    talk to joel-AE86 about it he has done it and im pretty sure there are pics on his car page
    Veteran slydar's Avatar
    Dimitri
    you can weld the inner back onto the outer. you will always get a little warpage. but you can reduce the amount of warpage by chasing your weld bead with a wet rag.
    just weld small spots one at a time in a row, and in between each spot cool the new welded area with the rag as you go.
    78's
    Jason
    Gold Coast
    thanks fellas, yeah also outer gaurd is not bogged or repainted yet so thats not a drama
  1. Rear guard welding???
    By Ksevn-T in forum Technical - Questions
    Last Post: 12th June 2012, 04:22 PM
  2. Ke70 rear outer sunshade
    By sleeper_13 in forum Cars or Parts Wanted
    Last Post: 29th March 2012, 06:51 PM
  3. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  4. outer o ring
    By d1doony in forum Technical - Questions
    Last Post: 26th April 2008, 10:38 PM
  5. little bit more outer 4ac
    By Chippie in forum Technical - Questions
    Last Post: 16th July 2006, 11:51 PM
