probably wrx
... or something like that.
any idea what these are like and what it might be off?
thanx
probably wrx
yeah possible WRX or maybe a 4G63 or 4G93, out of GSR or earlier EVO?????
you probably can run this round 12-14 psi level without too many dramas. i have a mate who is running one at 15psi for over a year with no dramas.
ring a turbo shop with the specs. they will be able to tell you the vehicle it was from and some other specs to match....
awesome what a score... what are these worth in good condition? currently the bearings are dead or something though will fix it if possible. anyone have any experience with doing this?
thanx
its from some versions of the 4g63 or 'evo motor', the automatic rvr's and older gen evo's had them factory. in good nick they'll hold 15psi without a drama.
sweet as!
so would it be much of a dramar fixing this thing? i might ring some turbo places anyway.
if your going to do that, just get it hi flowed.should be about $800 depending where you go, and will make much more boost.
if its a td04 it can hold like 25psi, but will run out of steam, and td05's can hold if that and more....but they are a pretty laggy turbo
4g63 (evo engines) run td05's. wrx's run IHI turbo's... i will find out for sure but i think the td04's are fitted 4g93 (gsr lancer)
I have a mistu td05h-16g on my 4a
I wouldnt describe it as laggy but it's not as responsive as a t28.
