Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Won't let me hold engine at ~2000rpm
  1. #11
    Veteran driftism's Avatar
    Andrew
    Watsoia
    Mine was really jerky when the TPS was out, sounds similar to this problem.
  2. #12
    Oldschool Member
    Aug 2005
    you can adjust it with guesstimates... or read the 4age workshop manual on how to set it... but i hate feeler guages so i just put a throttlebody on that had tps set to it since factory. honestly i think yours is working fine, and it might even be worth taking it to an auto electrician with a workshop manual (or a printed page from the pdf version).
    just for fun, unplug the tps and go for a drive. I bet the problem goes away.
  3. #13
    Michael
    Will try it with TPS disconnected, but I'm sure that will stop the problem. Thanks very much for the pages from the 4age manual - I've been downloading them, but it is a very painful process on dialup!
  1. Engine Runs rough while under 2000rpm under load.
    By Kwan in forum Technical - Questions
    Last Post: 17th February 2011, 09:05 PM
  2. Engine won't turn over, seems to be seized.
    By PULSE in forum Technical - Questions
    Last Post: 2nd September 2008, 04:43 PM
  3. Texas Hold 'Em Poker!
    By Bustin_86 in forum Offtopic Discussions
    Last Post: 5th July 2008, 09:51 PM
  4. Engine won't start after cold night
    By Mello in forum Technical - Questions
    Last Post: 13th March 2008, 03:16 PM
  5. Engine won't rev over 4000rpm
    By LeviNafey in forum Technical - Questions
    Last Post: 7th August 2007, 10:16 PM
