Results 1 to 10 of 13
Thread: Won't let me hold engine at ~2000rpm
    Michael
    I first noticed this when I had a flat battery and I was sitting in the car giving a few revs to try and charge it up a bit. If I tried to keep it sitting on around 2000, the revs would continually drop back down to idle speed, even though pedal position was unchanged. Had to take my foot off the pedal and push it in again to get revs back, but then after a few seconds it would happen again. This also happens when I'm crawling up my driveway trying not to tear the bottom out of the car.
    Is this abnormal? or is the computer thinking the idle is too fast and adjusting it back down?
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I've noticed this in mine. I've got the JDM 4age. I never really thought much of it at first, only happens when I'm just trying to keep it at revs, haven't noticed it anywhere else.
    Jul 2009
    what happens if you accelerate more as it dies down?
    Michael
    The revs drop back to idle very suddenly, so haven't tried accelerating while its actually dropping. When driving normally and shifting up through gears its fine, only happens when trying to crawl around at a constant low rpm. Will mess around with it tonight and pinpoint exactly when it occurs.
    Jul 2009
    sounds bizzare.. but yeh.. see what happens..
    Oldschool Member
    Aug 2005
    check the tps - if it thinks you have closed throttle, if the idle contacts are closed, but you foot is a little bit on the throttle bringing the revs up, it will rev cut back down to idle. do a search for 'hunting'.
    does it do this when the engine has warmed up
    Elite rthy's Avatar
    Leo
    Tulla
    i had a similar problem... found out my fuel filter was the wrong way...
    30kw club
    Michael
    Lol, I'll check that, but reckon its the TPS - have seen a couple of other similar threads now that I know what to look for.
    Have just done some playing around and found out that the revs cut out at 1700rpm - dropping back to idle of around 1000. If the throttle is open exactly the right amount, the revs go up and down repeatedly. If you open the throttle while the revs are dropping, it almost causes a stall.
    After reading this thread I'd say its the same problem - TPS needs adjusting as its not registering the throttle as open until after a certain amount.
    Paul
    Yeah sounds quite similar.. Try adjusting the TPS, and then borrowing someone elses to see if your tps is knackered
  1. Engine Runs rough while under 2000rpm under load.
    By Kwan in forum Technical - Questions
    Last Post: 17th February 2011, 09:05 PM
  2. Engine won't turn over, seems to be seized.
    By PULSE in forum Technical - Questions
    Last Post: 2nd September 2008, 04:43 PM
  3. Texas Hold 'Em Poker!
    By Bustin_86 in forum Offtopic Discussions
    Last Post: 5th July 2008, 09:51 PM
  4. Engine won't start after cold night
    By Mello in forum Technical - Questions
    Last Post: 13th March 2008, 03:16 PM
  5. Engine won't rev over 4000rpm
    By LeviNafey in forum Technical - Questions
    Last Post: 7th August 2007, 10:16 PM
