Results 1 to 10 of 13
Thread: Diff centre help needed
    Senior Member Brenton 86's Avatar
    Brenton
    I have purchased another rear end and the centre looks like this:
    This isnt my picture but it looks eactly the same. Is this an s-seies?? The crown ratio is 3.9. I was assured it was but its not the same as the one i pulled out of my car when i went to swap them.
    The diff centre that i pulled out of my car is slighlty bigger, has bigger axles, the tailshaft piece was bigger and had a larger distance between the holes and unfortuanaterly the ration was unreadable but looked similar to 3.9 . The centre looked ,much different with the spider gear enclosed in a extensive bracket with very limited access to gears. Also its 100% open wheeler, not LSD or mechanical.I seems like it could be a t-18 but i have never seen one and i know the previous owner dosent no wot a t-18 is let alone swap one.
    Another possiblity is could it be factory?? my sprinter IS ADM but its the Super Response (SR) model similar to the Ae17 spirit (SR) model, could this had a factory t-18 rear in it as an upgrade??
    If anyone has pics of a t-18 centre please please post them or pics of ur s-series
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
    Veteran slide86's Avatar
    Huw
    Hills
    how many bolt holes are there on your diff?
    *edit*
    super response model?
    every aussie ae86 had the super response badge
    because the 4ac was super responsive
    Brenton
    Im not sure but they looked almost identical from the outside casing but the centre is completly different. As both diffs are at the workshop i cant check til monday.
    Also iv got four friends with spriners an im the only one with that badge....i though my one was special
    Also Cass does the centre in the pic look the same as ur old s-series??
    Could it be possible they are both different models of s-series, cos both of them should be
    ADM 4AGZE SPRINTER
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    10 bolts = t series
    8 bolts = s series
    Will
    that is definately not an S series - S series has 6 "spider" gears (one for each axle, 4 "in betweens" the T series only has 4 gears in total)
    Veteran slydar's Avatar
    Dimitri
    it is definately not S. S has a differant looking centre as u described. no differance in deiffs between SR badge models and others.
    as mentioned. t ten bolt s 8 bolt.
    78's
    Brenton
    Thats wot i though, the one i pulled out of my car is an s and the other is a dud, Thanks for clearing up the confusion.
    ADM 4AGZE SPRINTER
    Veteran biggo's Avatar
    Nick
    Noosa
    Thats a t series center for sure. Ive had one apart.
    As i mentioned mate, you have ALOT of space to weld
    Brenton
    I dont think it could be because the axles where much SMALLER in the diff in the pic than the standard s series
    ADM 4AGZE SPRINTER
    Huw
    Hills
    the diff you have pictured also has had all the spider gears welded up creating a locker.
    you can check the ratio of the centre you pulled out by counting the teeth on the crown wheel and counting the teeth on the pinion. then use the simple formula to work out ratio.
    the formula is driven divided by driver.
  1. Wtb adm sprinter diff, diff centre or crown and pinion.
    By Ade_Mc in forum Cars or Parts Wanted
    Last Post: 31st July 2012, 12:00 AM
  2. Replies: 1
    Last Post: 15th January 2012, 09:11 PM
  3. Replies: 2
    Last Post: 30th September 2011, 04:35 PM
  4. Open centre zenki type T Diff centre + front snout
    By LordNafe in forum Car Parts For Sale
    Last Post: 21st May 2010, 12:58 PM
  5. f series diff centre needed
    By hks-to4r in forum Cars or Parts Wanted
    Last Post: 24th May 2009, 11:36 PM
