Results 1 to 7 of 7
Thread: compression
    Senior Member darkon's Avatar
    Shawn
    ACT
    Canberra
    hey all my car is running a 1mm head gasket and has flat-top semi skirt pistons in it. the compression is 8.7. iv been rackin ma brain thinkin of a way to raise the compression so i was just wondering if there was any cheap, easy way to do it n give it a little extra edge.
    thanx all
    Oldschool Member
    Jan 2006
    run a smaller head gasket...
    Veteran slide86's Avatar
    Huw
    Hills
    TRD have gaskets at several different sizes
    0.5mm and 0.8mm are ones i can think of at the moment. they will bump the comp up a bit. while the head is off, you can have it faced. that will help a bit.
    Shawn
    ACT
    Canberra
    faced? could you explain this to me please? never heard of "facing"
    Huw
    Hills
    the surface of the head that goes onto the block is flat.
    if you get this surface machined and have a very small amount taken off, this will make the combustion chamber smaller.
    smaller area with same amount of air = higher compression.
    there is a limit to what a machine shop will remove. you dont want to take to much off, otherwise the head is no good and un repairable.
    Jul 2009
    i took 20 thou off my head, and 10 thou off the block.. (the head needed to be straightened first though.. with a bit of post work.. came up very very well..
    B
    nsw
    glenwood
    aus
    As for cheaply, there are 2 lots of pistons cheaply available
    The ACL 100KW ($200 a set) and the Toyota 100KW (about $400 a set) (see below)
    The Toyota Pistons are raised further then the ACL,
    I am running new Toyota pistons in my engine, which also might have a ceramic top coat similar to the forged pistons (see below), as well as a 0.5mm TRD head gasket, The combustion chamber has also been cleaned up and 10 thou off the head and block to get a good clean mating surface. The engine does not ping with set up on 98 octane fuel, but does on 95/92 so its probably close to the limit.
    Ben.
  1. Compression rates
    By VeRm69 in forum Technical - Questions
    Last Post: 14th May 2008, 12:16 PM
  2. no compression
    By kaneO in forum Technical - Questions
    Last Post: 27th November 2007, 10:34 AM
  3. Compression ratios
    By Jazz9 in forum Technical - Questions
    Last Post: 17th September 2007, 01:43 AM
  4. compression test
    By albertos in forum Technical - Questions
    Last Post: 17th June 2007, 11:19 PM
  5. Any one know what the gze compression should be?
    By 4agze-hachisaurus in forum Technical - Questions
    Last Post: 13th May 2006, 07:51 PM
