i had an idea of turboing the 4ac (when i get it in) but that was going to be far too costly
i have had another idea. stuff turbo, its too expensive, what about supercharger (it maybe cheaper). i could just grab one off of a 4agze, make up some custom mounting brackets, lower the compression, run some piping, under drive it to prevent 4ac killage as soon as i turn the key. supersharger scream!!
costs
s/charger $150-200
intercooler $50
piping $50
massive thick h/g $30??
pulley thing $20
= $250-300
turbo was going to cost aprox $800!!
offcourse there is the bigport 4age option again $850 minimum
i think this will be a much more viable option than the last. i know that a 4age would be best and i would rather i 4age(i think) the any old crappy 4ac. the thing is i would be willing to push the 4ac harder i would a 4age. i would tend to baby a 4age but a 4ac it would be all on...
oh and some more questions
1) would a gze s/c be the best option? they seem cheap
2) how do you control the boost? im asuming with the pully sizes
3) do the boost vary like a turbo or dose it stay the same although the rpm?
4) do s/c have a thing in em to reduce to boost when you get off the throttel? (compressor bypass i think) how would i get on if it is surpost to run 12psi and you want to run 8psi? would you be able to ajust? it dont surpose it works like a turbo wastegate?
any comments/sergestion/answres to my questions would be aprecated
thanks
