Results 1 to 10 of 10
Thread: one question
    Oldschool Member
    Apr 2006
    guys one question nolathane or superpro bushers?
    mainly using car for drift oh bushers for swaybar and linkpins
    thanks guys
    Will
    superpro
    (based on nothing)
    parrot
    Although I had a superpro steering rack D bush which was nowhere near the right size. Had to grind it down to fit (still very tight). About to put in some noltec control arm, trailing arm and radius rod bushes so will be interesting to see how they go.
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    I have heard superpro are stiffer than nolathene, cant confirm though.
    Jul 2009
    i can confirm personal experience.. not only in preformance cars... but gerneral road cars... eg taxies.. falcadores come in for bushes.. Nolethane is used... come back in 2 weeks later.. bushes split and falling apart..
    replaced with superpro.. never heard a bad word.. plus they come in different stiffness.. and offset bushes available in some parts..
    call fulcrum direct.. and by from them.. no middle man..
    parrot
    Whatever you put in, make sure you install them properly. i.e. Don't tighten them up until you have the car on the ground and suspension bearing the weight of the car.
    Rob
    Moorabbin
    super pro FTW, qld company, but they are advertised in jap magazines aussie rep!
    Oldschool Member
    Apr 2006
    thanks guys u have made it an easy pics. mattysshop i agree being a mechanic as well we have a customer with a mx5 and we have fitted superpro cause nolathane only last 1 meet
    Installed a complete set of noltec bushes in my 86 when I bought it, they are shite, stick with genuine nolothane or whiteline bushes, I have the nolothane ones in my car now, they are sweet.
    Veteran biggo's Avatar
    Nick
    Noosa
    From experiance, get rubber ones for the caster rods.
    Everything else can be done in superpro. Ride quality will be improved greatly
  1. got a question.
    By metha in forum Technical - Questions
    Last Post: 7th September 2008, 09:06 PM
  2. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  3. Question....
    By arod in forum General Topics (No Technical Questions)
    Last Post: 25th June 2007, 09:06 PM
