Results 1 to 10 of 18
Thread: engine light
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Still have an O2 sensor installed? Mine does this but I'm led to believe because my speedo doesn't work it's the speedo sensor.
    Allthough when I got my extractors and exhaust work done they didn't install my O2 sensor and the engine light was coming on from around about then.
    Site Supporter Javal's Avatar
    Josho
    AE86's don't use an electronic speed sensor - they have a mechanical sender on the gearbox which runs off the layshaft (?), which spins a sheathed cable, which goes straight to your speedo.
    At no point does it interact with the ECU.
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I dunno this is what I was told, when I posted it up a while ago. I know they use a small plastic gear and a cable set-up. I just didn't know whether it was different due to GT dash, not ADM cluster. Has to be my o2 then.
    Edit: Just searched Club4ag, and there is definately a speed sensor. On my ecu/dash anyway. See bottom right corner. Sorry bout the size.
  1. Check engine light
    By bennyq in forum Technical - Questions
    Last Post: 18th November 2011, 09:58 AM
  2. Check Engine Light
    By Dish in forum Technical - Questions
    Last Post: 20th September 2008, 11:41 PM
  3. problem with engine light
    By stej in forum Technical - Questions
    Last Post: 27th February 2008, 09:58 PM
  4. Check engine light
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 28th August 2007, 09:16 PM
