The wiring should be exactly the same as far as I'm aware, both set ups use h4 globes and the indicators are identical.
my lil bro is getting a ke70 but the slant front end but he wants to run the other type of front stylez! as displayed below.. as far as wiring goes does the shiz just chang over real easy??
the first pic is the desired look! be dawggy dori dori!1
Driver of the yellow ae86
http://www.ae86drivingclub.com.au/fo...hlight=custard
Indicators are on side of parkers in slope nose ...do they use same plugs ? ..don't forget you'll need flat nose bonnet and gaurds .
i think the door curve is the same
but the square lights are sealbeam, where as the slope headlights a h4
plugs for the headlights are different and you will have to do some rewiring to get the fender indicators to work.
awsome.. thanks guys
