hey mate,
i have a sr20 ae71 and still have a little gap over where the shifter is, what can i do to cover it up neatly like you did, what did you do to make your so clean and tidy on the inside coz i am getting hot air coming through.
Completely cut out the shifter area
[attachment=9417:attachment]
Then make up a plate to cover the hole and weld and sikaflex it on, then you can cut out the old holes that the shifter boot screws into then weld them underneth the new plate and then drill threw the new plate to expose the boot screw holes or maybe you can use tech screws to fix the boot im not shore.
[attachment=9425:attachment]
Let me know if that doesnt make sence or if that wasent what you were after.
hey man do u hav much clearance when cars in second between handbrake an gear stick..
mines is really close jus wonderin if ya did anything t give more clearance?
cheers shaun
