^^ BAHAHAHA!!!
geez i wish i had the luxury of those options foe a daily!!!!
how about L20b!
^^ BAHAHAHA!!!
Go 20B or 3RZ i reckon... ARE wrung 484kw from a 3RZ.... now THAT would fly.
20b all the way
Carbs ftw.....and post up your mods and results so I can copy you!
If the quality is anything like your ae86 it will be a stunner
Driver of the yellow ae86
http://www.ae86drivingclub.com.au/fo...hlight=custard
Definitely put an L20 with a 32/36 Down draught in it.
Seriously though, if you go the twin carb set up, can you tell me how you would go about the problem with the dizzy?
What problems with the dissy, the early 4AGE motors run an electronic dissy that is not controled by the computer, so just wire it up, put in some dummy injectors and whhhhooooohhhhhoooooo induction noise here we come![]()
Definately wouldnt do the 3SGTE..thats a $9,000 conversion (including motor). Would go 4AGE with twin carbs. It is what i will be running. The only problem with running the early dizzy with no mods is that you will have no vacume advance.
4k ftw
there is a way of getting vacume advance on the electronic Dissy but, I am keeping the details quite till I have proved it will work.
I am fairly sure I will fit the carby 4AGE for the time being, when I get bored with that I will revisit the conversion and do an upgrade.
Cheers for your input
Jon
