Any better explanation? Whats the rattle sound like?
noticed a rattle coming i think from the throttle bodies, the rattle sound increases as the rpm increases, has ne 1 heard ne thing like this b4 ? ill hav a look at the throttle bodies but could it be sum thing else ?
thanks
ticking which is gettin louder on idle
not good news, had it checked out mechanic reckons big end bearing fucked![]()
thats common for 20V engines that are given crap oil. Dont continue to drive it or else you will likely need to grind your crank.
yep stoped driving its at my work right now but im shatted, it could be the oil cooler that i installed about 2 mnths ago that fucked it up
why would it be from the oil cooler?
it could be blocked, doesnt matter now anywaytoo late
