Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Other Throttle Bodies
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Default Other Throttle Bodies
    Hey guys,
    I did a search but couldn't find anything, I think the stuff I am thinking off is possibly on the old forum.
    I'm wanting to know if there are any larger throttle bodies that can be bolted on with minimal mods. Obviously I will need to run the same TPS for everything to work.
    If anyone knows of any that are direct fit for a JDM bigport 4AGE.
    Cheers.
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    i think EFI hardware make a setup for the 4age maybe give them a call
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    a land cruiser one? i remember reading something about that on the old forums
    FTP.
    Akio
    Mt Haruna
    Japan
    a 3SGE will be minimal mods 65mm? size
    a xf falcon throttle body (requires map sensor) 75mm size
    a landcruiser will work little bit of pfaffing about with it though 70mm size
    a V6 camry one cant remember if it just bolts up though 65mm size
    a 3rz one will work at 70mm? size
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    gtir?
    gay
    n1gger land
    n1gger land
    south korea seoul
    i used a v6 camry throttle body on my smallport. its a 3inch one, same as sr20 size.
    barely clears the trueno bonet tho !!
    gay
    n1gger land
    n1gger land
    south korea seoul
    i think lawson was talking about using 4 of 6 gt-r throttle boddies on a 4age as quads.. it has been done before.
    Jason
    Nundah
    Why would you want to change it..??
    Unless you have a crazy engine there is apparently almost no gain to be had from running a bigger throttle body...
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    your wright there is no gain al all of running a bigger throttle on a 4age but 4agte or 4agze maby but even then why bother with a bigger throttle body upgrade something else for a little more go
    the dyno pull to 300rwkw
    Oldschool Member
    Mar 2005
    Roy
    Bris
    So you've guys have done it and tested flow rates? I doubt there would be zero gain.
    The next step for me is a rebuild, so I don't know really why I would rather spend 2-3k on a rebuilt or $50 on a slightly larger throttle.
  1. silvertop throttle bodies
    By spoon in forum Car Parts For Sale
    Last Post: 23rd July 2007, 11:20 AM
  2. quad throttle bodies
    By Cerby in forum Technical - Questions
    Last Post: 24th January 2007, 10:49 PM
  3. 4age throttle bodies
    By brad in forum Technical - Questions
    Last Post: 26th September 2006, 07:12 PM
  4. Throttle Bodies
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 24th March 2006, 05:42 PM
  5. throttle bodies
    By Insane in forum General Topics (No Technical Questions)
    Last Post: 19th July 2005, 04:41 PM
