are s series bearings the same as t18 or the zanki t series?
Koukie wheel bearings? Theya re differnet to zenki. Can get them, but are quite expensive.
No there are not.
Insert witty comment here....
hi i need a t series diff but what diff did the ra40 celica come out with?
JAPANESE DOMESTIC MARKET AS F*CK!!! hmmm, when you prenounce it properly, it sounds gayhow bout that.
RA40 has a t series. the mounts are slightly different though so they don't bolt straight in like a T18 t series does. also they are wider. the useable parts of an RA40 diff are the centre, brakes and axles, though the axles need to be shortened 5mm at the splined end otherwise they rub in the diff centre (found that out the hard way)
ah cheers heaps gilly bt ive managed to trade my s series recently serviced for a t18 diff swap for sawp!
ill change it ovet on sunday! then drop my locker into it!
Ring spanner wont fit on the drain, there is a large ring around it. To stop the nut being ripped off accidently no doubt. I found a hammer and coal chisel was most helpful.
slight correction..
zenki JDM axles have the same double row (extra wide) wheel bearing as kouki axles.
t18/celica use the narrower bearing.
78's
Quick question regarding the diffs....
AE86 T and S series, are they both 1410mm wide?
Also, what are the widths of the other T series diffs?
RA23 - 1365mm?
RA28 - 1365mm?
RA40 - 1410mm?
RA60 - 1410mm?
TE27 - 1410mm?
Just need validation for these diff widths...if anyone knows if they are correct.
PS I took the measurements form the Toymods diff database. So if they can be confirmed, that would be very helpful for anyone finding one to mod into their AE86 (and know the diffence between diffs).
I would say that RA60 diffs are not the same width as AE86 and TE72. I've used RA60 axles a number of times and they need 10mm ground off the end of each axle. So I'd guess they are 1430mm drum to drum.
I'd also hazard a guess that RA40 width = RA60 width.
