Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: 4AGZE pistons
  1. #11
    Veteran biggo's Avatar
    Nick
    Noosa
    Sorry i couldnt be of more help man, but from memory Nebuchenerzer (sp?) was doing something along simular lines...
  2. #12
    Oldschool Member
    Mar 2006
    The 01 02 03 at the end of the part numbers refers to minor differences in outside diameter of the piston. Which is nothing to worry about if you are getting your block bored to suit the pistons. The difference is small 01 being the smallest and 03 the largest and I think the difference in size is about 0.10mm from 01 to 03. If you use these pistons you get the block bored to 81mm (this can change depending on application) as the pistons are slightly smaller eg. 80.9mm. Hope this helps a bit.
  1. 4agze pistons
    By nath85 in forum Technical - Questions
    Last Post: 8th May 2012, 05:25 PM
  2. 4agze pistons
    By spooldog in forum Technical - Questions
    Last Post: 5th July 2011, 09:42 AM
  3. wtd - 4agze pistons
    By ae71turbo in forum Cars or Parts Wanted
    Last Post: 17th April 2010, 08:27 PM
  4. 4agze pistons
    By greenmac80 in forum Cars or Parts Wanted
    Last Post: 14th July 2009, 01:19 PM
  5. 4AGZE Pistons
    By Gazza_ae71 in forum Cars or Parts Wanted
    Last Post: 3rd September 2007, 12:01 AM
