Results 1 to 5 of 5
Thread: AE86 Water Supply For Turbo
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    Was wondering where people have sorced there water in / out for the turbo on a 4AGTE.
    I currently have water from the Water drain on the block and was wondering where to get the other connection to, either heater hoses / radiator etc.
    Please and ideas appreciated and pics would be great also
    Thanks
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Veteran slide86's Avatar
    Huw
    Hills
    i would use one T'eed into the heater hose for the feed, that way it doesnt run all the way round the engine, just to the back.
    Craig
    Upper Caboolture
    slide86
    Have you got any pictures of where exactly you connected into ?
    Huw
    Hills
    nah', but i did it recently on a r32 with bigger turbo. i just went down to bunnings and found a brass T piece.
    then i cut the heater hose and fitted the T in. adding a line with a banjo fitting on the end to bolt to the turbo was the last step.
    it worked well and the car is still going.
    GoldCoast
    here is who mine is done, the line then just runs around the back of the block, she's all good
    [attachment=5283:attachment]
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. 4agte turbo water line setup?
    By ae86 slide in forum Technical - Questions
    Last Post: 21st January 2012, 09:02 PM
  3. where to cut into heater for turbo water lines?
    By Nic19 in forum Technical - Questions
    Last Post: 6th July 2009, 07:42 AM
  4. turbo water and oil plumbing
    By slidn_ways in forum Technical - Questions
    Last Post: 30th May 2008, 07:56 PM
  5. ECU Supply/install recommendations
    By Whip in forum Technical - Questions
    Last Post: 2nd August 2006, 08:35 AM
