first off, learn to spell and grammartise.
then look at GTiR setups
why do you want quads on a turbo engine? you need to run a plenum and miles of inlet pipe, just use one reasonable sized throttle and a sensibly sized turbo
yeh im juz wonderin because im goin through this setup.and everyone is tellin me they have had problems
and i have heard of two ways to get a MAP sensor readin which way is better
-4 vacuum lines bein T peice together to the 1 and then to the MAP sensor or
-4 vacuum lines goin into another custom cylinder.then from dare u can get a pressure reading and hook a the booster up to
please help![]()
im askin for help not smartass remarks
why do i wanna run quad throttle turbo?
why does a gtr have six single throttle setup?and why is the gtir sr20 is better then the single throttle bodied sr20.....that is your answer coz its better agree![]()
Quads, flow better, more flow more power, with good response for a na engine, when you turbo it, well things change a little.
big HP GTR's run single throttle bodies..making a sealed air box that will hold boost isn't going to be the easiest of all things on a 20V quads setup for example..
yes.. they hate Map sensors..
