You have to use the whole GZE engine loom and wire in stuff like alternator etc. from your 4AC stuff. A lot easier to go aftermarket.
Just a Question What WIRING do you use on the 4agze. Adapt the 4ac wiring to the 4agze or use everything from the 4agze?? If anyone has done it???
A quick inspection of your 4AC will show about 10 wires leading to your engine.
From the top of my head:
- 2 to carby. Unplug and forget about these.
- 5 in a black plug attached to the firewall. 2 for reverse light switch, 1 for oil pressure, 1 for water temp and 1 for starter signal. These all should be reattached to the new engine, though only the starter signal is REALLY needed.
- A few to the alternator. This gets a little tricky as the 4AC has an external regulator, while the ZE has an internal regulator. However it has been discussed before and really isn't too hard to change over. A look at a wiring diagram will explain it too.
Everything that is needed to run the engine should just come out of the ZE loom.
Good luck
Hey thank you very much for your help guys.
Cars been off the road for way to long hey.
Cheers for in4 guys
