Results 1 to 4 of 4
Thread: Grinding scraping noise?
    Alex
    Queensland
    Gold Coast
    hey all i was hoping someone might be able to shed some light on this noise?
    when i am almost stoped e.g parking and stuff (no noise when i turn when goen like 30km/h+)... their is a pretty bad metal scraping/grinding noise coming from my front left wheel area, but it only happens when i turn...
    I thought it might have just been my front left spring fell out (as its held in with zip ties), but it only hapens when i turn & there is no noise out of the usual when i hit bumps...
    Another thing... it just hapend all of a sudden... their was no noise... then BAM... grind...
    i am a mechanical noob so yeh... any info will help heaps...
    Thanks
    -Alex
    Aaron
    In the Mountains
    mate jack your car up, take off your wheel and have a look to see if there is anythink obvious.. abd check around your gard etc for rubbing, my datto used to rub only on the left every time i pulled into my driveway.. it had chucky tyres...
    Jason
    Gold Coast
    check ya pads
    Veteran slide86's Avatar
    Huw
    Hills
    also check the brake disc baking plate that its not hitting on the disc.
    but id be checking pads too
  1. grinding letters off rx7 calipers
    By shift_rook in forum Technical - Questions
    Last Post: 1st November 2010, 01:27 PM
  2. Front right brake sounds like its grinding
    Last Post: 28th June 2008, 12:31 AM
  3. Drivers Door Scraping on Guard..
    By Dan_AE86 in forum General Topics (No Technical Questions)
    Last Post: 1st February 2008, 03:15 PM
  4. grinding nosie
    By jase ek in forum Technical - Questions
    Last Post: 23rd June 2007, 01:15 AM
