I was wondering if i am able to run an internal and an external at the same time, and select between them by a soliniod that will block the boost pressure used to activate the wastegates.
The reason i want to do this is so i can run the internal with the stock spring at standard boost levels for general driving, then activate the external gate (high boost) for track and late night mountain runs.
