Results 1 to 6 of 6
Thread: 4AGE Hybrid Swaps
    I was wondering if anyone had any information on hybrid engine swaps. Being a Honda person and knowing a lot about Hondas and not much on the 4age, that hybrid swaps can give amazing results, such as a b16a head on a b18c block.
    Getting to my point is there any benefits from using a 20 valve silver top on a 16 valve block. Is there any flow and performance gain. Or is there a better swap with in the Toyota engines.
    Dxaqta
    i personally dont know alot about engines but ther are lots of option like using 20v block with a 16v head. Some other hybrids are 7ages using a 7afe block with a 16 or 20v head also 5ages which is a 4age using a stroker kit
    the best option to find out information is to search on google as, most poeple on here have a limited knowledge about engines and every possable combination that you can thank of would have been done and will be on the internet
    Veteran driftism's Avatar
    Andrew
    Watsoia
    As far as i know you won't get any benefits from fitting a 16v block to a 20v head. the 20v bottom ends are tougher, and have higher compression anyway, so changing it isn't really worth it. the only time you may consider this is if you are making a turbo 20v engine, and want to put the GZE pistons into the 20v to lower the compression and hence make it more boost friendly.
    As Dxagta said... google it and you'll find a fair bit of info available,
    or search the tech forums on here.
    Thanks for the information and I will post the what i find for others to use.
    May 2010
    Fletcher
    Wollongong
    the most common hybrid motor in the A series stable is the 7AFE Block + 4AGE Head, commonly known as the 7AGE. You can use the AE82/AE86/AE92/AE101/AE111 (16v or 20V) heads. You also need to use the corresponding piston to suit the head ie 20V head, use the 20V pistons. The 7afe head with any of the 4AGE heads will only yield around 8:1 compression. The downside of this hybrid is the stock rods are quite weak,lmiiting the max rpm to about 7-7.5K range. You can get aftermarket rods for about $1000. This hybrid is quite well discussed on Club4AG () and toymods ()
    Dxaqta
    nothings weak if you build it right
  1. Ae71 4Age Watanabes T50 Manual Bigport Tuned Extractors 16V Swaps
    By pig70 in forum Cars for Sale (Toyota Only)
    Last Post: 7th November 2012, 04:05 AM
  2. swaps for 4age
    By koulouris#03 in forum Car Parts For Sale
    Last Post: 22nd June 2009, 09:42 PM
  3. Bigport / Smallport 4AGE Hybrid motor. ALL PARTS MUST GO
    By DavisJD in forum Car Parts For Sale
    Last Post: 7th May 2009, 08:50 AM
  4. hybrid engines
    By dj_chetti in forum Technical - Questions
    Last Post: 26th June 2008, 09:24 PM
