Results 1 to 10 of 11
Thread: 4age heater hoses
    Sep 2009
    ive been looking through all the tek manuals and these is no specific lines where heater box/valve plumbs in. Can any one help? also its a fwd>rwd 4age so its got a remote thermostat
    Veteran slide86's Avatar
    Huw
    Hills
    gday mate, i had the same problem a few weeks back, have a look at this and see if it helps
    Sep 2009
    hmmm it dosnt help to much that just confused me more?
    Terry
    Ipswich
    there is no real need to remote mount the thremostat unless you dont have enough room for the stock one. if you send me a drawing of what you have done, then i'll help. The correct plumbing for a 20V goes like this
    1) pumps cold water into the front of the block, behind the water pump
    2) water travels up thru block into head, and out back of head into housing
    3A)if thermostat is cold and foot valve is thus open, but main valve shut, then it does a u turn inside the rear housing and travels along the gallery inside the the head, and into the suction side of pump (back) via a short alloy fitting
    3B) if thermostat is hot, foot valve is shut and main valve is open, then it travels out the port on the LH side of the head, and to to top rad hose. The return from the bottom ratiator hose is onto the top of the thermostat
    the heater hoses take off at the back housing originally.
    Terry
    Senior Member Medicine_Man's Avatar
    Justin
    North
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    Sep 2009
    ok i kinda of get that diagram but i dont know which is the heater box
    heres a pic of my setup i did it before i realised i needed a heater
    Which is which i know 1 is the radiator, 2 pump, 3 therostat but what are the others?
    4 is heater tap.
    5 is throttle body.
    I think 6 is heater box.
    Sep 2009
    so the only reason for the little outlet on the back of the head is for a heater?????
    Justin
    North
    And for the thermo time switches..
    Sep 2009
    eh not for me
    uggggg more work
    so when the thermostat is cold it stop circulation through the radiator and just recyles the water through the block?
  1. Where to buy AE86 RWD heater hoses and thermo & heater gaskets
    By oz_eight6 in forum Technical - Questions
    Last Post: 22nd October 2012, 11:42 PM
  2. Jap rwd 4age heater hoses and jap front timing gear covers
    By 70rolla in forum Car Parts For Sale
    Last Post: 12th October 2012, 07:24 AM
  3. NEW RWD - 4age radiator / heater hoses
    By Matt in forum Cars or Parts Wanted
    Last Post: 28th February 2012, 05:13 PM
  4. Heater Tap...Where do the hoses go?
    By hugh in forum Technical - Questions
    Last Post: 3rd May 2009, 12:10 PM
  5. WTB: AE86 heater hoses
    By Dori86 in forum Cars or Parts Wanted
    Last Post: 22nd July 2007, 06:09 PM
