hey,
i removed mt turbo's the other day for inspection the shafts have minimal play but there was a small amount of oil around the front around the compressor.what does this mean?is it o rings or something minor?.
cheese dave![]()
hey,
cheese dave![]()
usually abit of oil in the compressor is ok, but not too much it could be just abit of grit/carbon etc. what you should be worried about is the exhaust side, is there any oil around the exhaust wheel? if so it is a high chance that you have blown your seals.
having oil in the compressor side can mean several things.
do you have crankcase breather connected on the inlet? thats probably what it would be. crankcase gasses going into the inlet and through the turbo. not a huge issue. heaps of cars are designed that way from factory.
the other thing could be a seal, but you would notice blue smoke when on boost and using oil.
yes it has a crankcase breather to the turbo and thats most likely the source as the oil was very minimal.
but i did notice alot carbon build up on the compressor on the rear turbo but the front was clean.
generally black build up on the rear wheel means its running rich
get it on a dyno to check the afrs
