Results 1 to 8 of 8
Thread: silvertop 20v or blacktop 20v
    Oldschool Member
    Aug 2005
    im jst contemplating whether to put in a silvertop 20v or a blacktop 20v for when i start up my new project drift spec ae86 ,, wats better , wats easier 2 get aftermarket performance parts for ,, any advice would be must appreciated thanks Corie
    Dec 2005
    basically the same
    black top is better.
    silver top is cheaper.
    its not a hard conversion to do .. but at the same time its not as easy as a 16v conversion.
    Senior Member stouty's Avatar
    Leigh
    Forster
    Have a look at the last two engines the AE101 is the siver top and the AE111 is the black top. Basically the black top has a little bit more power is a newer engine and revs better. They do cost a bit more being newer but if money isnt a big problem definatley go with the black top.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    Nafe
    Silvertop FTW. Yes, black tops are hotter. But is doubling the price worth 10hp or less?
    parrot
    If you plan to use the original ECU (which you probably aren't), remember blacktop is map and silvertop is airflow meter. Thus silvertop needs to use either the original airbox in front drive configuration, or a custom made well thought airbox for rear drive.
    if you go aftermarket ecu you can do what you want.
    Veteran slydar's Avatar
    Dimitri
    this thread has been asnwered remarkably well.
    ST w/aftermarket ecu is the best combo bang for buck. BTs are good but not worth the expense, they dont seem to make percieably any more power.
    78's
    yeah but tree the black top was neve about power
    For standard ECU conversion, black top is the way to go as factory ECU tune with map vs TPS is great.
    Aftermarket ECU either motors would do.
    Black top has longer duration cams and higher valve lift. The cylinder squish areas are also different, bigger throttle bodies, lighter pistons and crank. New engine, less k's.
    Silver top has stronger bottom end, heavier pistons, crank. Has better cam belt tensioner, smaller throttle bodies. Older engine more k's.
    Depends what you are going to do with the motor in so far as mods... will mostly determine what engine you should buy.
    regards
  1. 20v Silvertop vs Blacktop - What are the differences
    By Matt in forum Technical - Articles
    Last Post: 18th December 2012, 08:36 AM
  2. WTB: 4AGE 20V Silvertop or Blacktop around the 21st of March..
    By s3phro in forum Cars or Parts Wanted
    Last Post: 4th March 2011, 08:44 AM
  3. Blacktop 20v ECU on silvertop engine
    By 99Westy in forum Technical - Questions
    Last Post: 31st August 2009, 02:11 AM
  4. 4age 20v Blacktop vs Silvertop
    By shelldrake in forum Technical - Questions
    Last Post: 4th June 2008, 02:09 PM
  5. 20v: Silvertop or Blacktop???
    By HYPNTK in forum Technical - Questions
    Last Post: 3rd November 2006, 05:45 PM
