mallet![]()
"FF / MR mount 4AGE engines do not have a spigot bearing in the crankshaft. You can press a spigot bearing from an AE71/AE86 4A-C into the crankshaft"
i got this from rollaclub, sorri to be noob how exactly do i install 1 on.. is this an external part? or internal part
mallet![]()
How are you going to install it if you can't read the instructions given above and press it into a crankshaft?
Do you know what a crankshaft is?
when you take the clutch cover off.. you will notice that in the middle of the crank there is a 20 cent piece size machined recess in the crank.. get a spirgot bearing for a ae86/ae71 rolla i think it's 6005? i think! and press is in the a socket that rests on the steel casing NOT the race.
Sure you got it from toymods? Thats part of my 4AGE RWD conversion FAQ on rollaclub..
Why hesitate when you can accelerate???
Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
oh sorri from rollaclub sorri mate good write up thought![]()
cool thanks!
