Results 1 to 7 of 7
Thread: Clutch pedal adjustment
    Mar 2010
    Daniel
    West
    I want to adjust my clutch so the point of engagement is not at the very top of the pedal.
    I know there is an adjustment nut on the rod behind the clutch pedal which connects to the master cylinder, and also on the top at the front of the pedal there's another adjustment screw. Which one do I use, or do I adjust both? How do I set the point of engagement lower but keep the pedal at the same height?
    Mar 2005
    All I can say is the adjuster behind the pedal is a bitch to do.....
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    handy tip for doing the one behind the pedal, remove the seat and angle the steering wheel all the way up. I did it without having to remove any dahs or anything, so just stick with it lol. Only get tiny turns in though....
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    gah, softies...dont remove the seat its pointless busy work.
    now get on ur back on the foot well with a light and undo the nut ( i think its a 12mm)
    you obviously dont have much freeplay, so turn the pushrod anti clock wise ( if u have trouble turning that, use ur other hand to push down the pedal back and forth ever so slightly whilst turning the rod)
    Will
    i agree, no need to pull the seat out, get under there and have a good look with a torch, then sit in the seat and do it by feel, once you get a good mental picture of where everything is it should be a piece of piss
    Mar 2010
    Daniel
    West
    Thanks guys, I got in there upside down, unclipped the rod from the pedal and cranked on some more thread. Did the trick. Now I just need some more time to pull off the lower dash shroud and adjust the pedal height.
    Mar 2005
    The pedal height was the one I was refering to as been a bitch......
  1. clutch pedal/ gearbox maybe clutch plate issues
    Last Post: 28th January 2012, 12:28 PM
  2. Replies: 1
    Last Post: 19th October 2010, 04:30 PM
  3. Clutch pedal
    By Low Style in forum Technical - Questions
    Last Post: 10th September 2009, 01:26 AM
  4. Melb: Pedal assembly, hard clutch line and clutch master
    By stahlz_ae86 in forum Car Parts For Sale
    Last Post: 31st March 2009, 07:04 AM
  5. KE70 clutch adjustment??
    By shinny in forum Technical - Questions
    Last Post: 17th June 2007, 05:55 PM
