I used to have an e6x on my ze and it seemed too hard to wire it up with the cas cos it had the rwd dizzy wired up and working well
i also have another 86 with a jdm donk and it is running an e6k with a dizzy aswell. just keep the dizzy
hey,
ok, i am wiring in a haltech e6x onto a bigport 16v, i am using a watse sprake set up. my questiom is, do the ze engines run a cam angle sensor? and do these assemblies bolt onto a bigport head?
what type of singnal do these units send?
thabks brad
i have literaly just finished doing it (like 10 mins ago) its not overly hard once you read the faq toymods thread on toyota ignitons, there is a thread on toymods that i started as well, i was using a smallport dizzy and e6k (same wiring diagram as e6x).
ohh and to answer your question all 4age dizzys interchange (except 20v)
you can use your standard bigport if you want, but you need to cut some of the triggers off inside. or get a smallport dizzy or gze cam angle sensor and wire it straight up.
good link here
and
thanks for ur replys,
i have another question, is it possible to just run the cam angle sensor from a gze or do u have 2 run the crank sensor aswell.
does anyone have the serial numbers for the distributor and crank angle sensor from a 4agze.
i also need wiring diagrams too.
thanks brad
