Page 7 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 61 to 70 of 155
Thread: Brendon's ADM Sprinter
  1. #61
    AE71 Rolla
    Two slack fucks. :lol: :lol:
  2. #62
    AE71 Rolla
    Will be a bit laggy with such a large fmic but it will sing like pavarotti when it comes on boost.
    Good for a low 13 sec 1/4 mile
  3. #63
    Mar 2005
    Jason
    Queensland
    Maroochydore
    piping doesn't need to be pretty, thats what autosalon is for
  5. #65
    AE71 Rolla
    So true. it's built for thrashing round a track with a hint of rear end slide and not for "omg ule look at all that chrome".
  6. #66
    AE71 Rolla
    Pretty sure the big end's siezed as i can't turn the harmonic balancer/crank any more. There was oil in the engine when i started it up but it obviously didn't pump enough up through the engine. Very, very angry... and devostated as it only took 2 minutes to destroy it!!!!
  7. #67
    Veteran slide86's Avatar
    Huw
    Hills
    did you have an oil pressure gauge on it when first started? was the oil pump primed?
    didnt hear any big knocking noises?
  8. #68
    AE71 Rolla
    The oil pupmed was not primed coz i'm a stupid fuck.(i realised after) the thing is last time i started the engine up having drained all the oil it ran fine. i'm pretty sure it was also partly to do with the oil having to travel to a massive remote mount filter and fill it up which wouldn't have helped it. the top end is fine by the way.
  9. #69
    Huw
    Hills
    perhaps remove the sump in the car and ispect before removing entire engine again.
    you may be able to fit a new bearing to fix the problem. i have seen it done before and all was good.
  10. #70
    AE71 Rolla
    Dad and i are pretty sure that it's just the bearing that needs replacing. i didn't think it was possible to replace the bearing with the cross member in the way?
  1. Brendon's ADM 86
    By AE86 Spoontah in forum AE86 Owners Forums
    Last Post: 2nd December 2012, 08:36 PM
  2. lewwy's ADM sprinter
    By lewwy in forum AE86 Owners Forums
    Last Post: 25th May 2008, 12:40 AM
