what motor is in your car?
Anyone got an AE92 with the 100kw motor MAP sensored I can have a look at? I have put the 100kw ECU onto my AE86 along with the MAP sensor from same car but am having issues getting it to run properly. Before anyone asks, I have done the following, fitted the correct dizzy for this ECU, fitted the correct MAP sensor, wired it up as per the factory diagram (including pulling the lid off the ECU to make sure I have the right instructions) fitted the air temp sensor, reset the TPS, fitted new plugs and leads, checked the fuel pump pressure and tried just about everything I can think of. The only thing this car doesn't have is the coil and ignitor from the 100kw engine. A look see at the original engine in the original car could help to solve my issues.
Blackers
It is out of an AE92/93 Corolla GTi
