Results 1 to 4 of 4
Thread: tacho wiring.
    hey people
    I have a 4agze and its going into my ke70, it is dli so how do i hook up a digital tacho/shift light. Its a stewert warner ultra shift light and tach, It hooks up just the same as a normal tacho.
    It needs to be powered(red wire)and earthed(black wire), It also needs a signal(green wire) to the negative on the coil, I have two coils and there is one 2 prong going into each pack.
    any idea's or suggestions are very welcome.
    cheers des
    Elite rthy's Avatar
    Leo
    Tulla
    there should be a -ig on the ecu,
    i used it when my stock tacho wasnt working in in my ae82gze.
    there was a page on the net with info to do this....
    Does the stock tacho use the -ig wire or does it run another way?
    The tacho signal from your ECU is a 5 or 12V square wave. This will not work on your tacho if it needs a coil negative signal.
    You can combine the two negative wires from your coil packs using a small circuit and connect this to your tach.
    I've posted the circuit before on Toymods. Search for posts by "Hen" and "tacho" or similar.
  1. Wtb: wiring for jdm tacho cluster
    By Nate89 in forum Cars or Parts Wanted
    Last Post: 23rd November 2012, 01:18 AM
  2. Blacktop 20v tacho wiring
    By Jacobxxx in forum Technical - Questions
    Last Post: 25th May 2011, 03:42 PM
  3. Tricky Tacho Wiring?
    By bigm in forum Technical - Questions
    Last Post: 19th April 2010, 10:25 PM
  4. no tacho
    By Faceplant456 in forum Technical - Questions
    Last Post: 19th April 2010, 08:29 PM
  5. Replies: 4
    Last Post: 29th March 2008, 10:30 PM
