Sorry to hijack but im having troubles with them too. I was wondering what the part number is for the window clips that hold the side windows in and if anyone knew the cost?
Thanks
Hey guys,
I was wondering if anyone would have the toyota part numbers for genuine 4A-GZE pistons and head gasket? I am trying to purchase them localy off toyota but the spare part monkey cant find the part number to place the order![]()
Cheers.
Thanks
I think its really catch22 with dealers and parts... they tend to not want to sell parts or generally dont know what parts without you telling them the part number you want.
That said if anyone has the part number for the gearbox speedo pin let us know
Sorry ae86 represent, doesn't help you but might help stouty. I might have the 4agze numbers you want but they are on my work computer if I have. Will look tomorrow.
Have a hunt through and you might find what you are looking for. If not, useful for another day. Cross reference the diagram to the listings for what you want.
dont know if this is useful to you guys
but has been handy for me in the past
I work for Toyota in spare parts, and because the 4AGZE's wern't an australian produced engine therefore all our part numbers have to be sourced thru sydney from Japan.
And to go thru sydney you have to have VIN numbers, model numbers etc etc..
try and look for an austrlian EPC it will have all the parts number you need
This is a parts list for an AW11 I got off the net a few months ago. Appears to originate in Germany. Note only the top bit is specifically for supercharged. Below that including head gasket is presumably AW11 4AGE. Of course I can't guarantee these are right so check anything first. If you want the whole AW11 part list, PM me your email and I will send it. Is in Excel. You will need to fix the formatting below to differentiate the PNC and part number as I can't do it in the forum. Might help a bit.
Supercharger
Part Name PNC Part Number
Bracket, Sub-Assy, Supercharger 17605A 17625-16010-
Clip (Air Hose No 7) 17347A 96132-30600-
Cover, Housing, Front 17676 17676-16011-
Cover, Rear (Supercharger) 17666 17666-16010-
Elbow (Supercharger) 17064A 90407-06004-
Flange, Clutch 17665 17665-16011-
Sub 17665-16020-
Gage, Supercharger Oil Level 17679 17679-16010-
Gasket, Housing Front Cover ($49.85each) 17677 17677-70010-
Gasket, Rear Cover (Supercharger) ($12.53each) 17667 17667-70010-
Gasket, Seat (Supercharger) 17666B 90430-12005-
Guide, Supercharger Oil Level Gage 17678 17678-16010-
Hose, Air, No 7, No 1 17347 17347-16010-
Hose, Air, No 7, No 2 17347 90445-12196-
Housing Sub-Assy, Rotor 17064 17064-16011-
Hub Sub-Assy, Clutch 17068 17068-16010-
Idler Assy, V-Ribbed, No 1 13570 13570-16010-
Pipe Sub-Assy, Air 17303N 17303-16060-
Plate Sub-Assy, Rotor Housing, RR 17065 17065-16011-
Plug Sub-Assy, w/ Head Straight Screw 17666A 90341-12019-
Pulley Sub-Assy, Clutch (est $326.75) 17067 17067-16010-
Ring, Shaft Snap (Clutch Pulley Sub-Assy) 17067A 90179-30006-
Ring, Shaft Snap (Clutch Stator Sub-Assy) 17069A 90520-37003-
Shaft, Idler V-Ribbed Belt 13583 13583-16010-
Shim, T=0.1, Mark 1 17068A 90564-08001-
Shim, T=0.3, Mark 2 17068A 90564-08002-
Shim, T=0.5, Mark 3 17068A 90564-08003-
Shim, T=0.7, Mark 4 17068A 90564-08004-
Shim, T=0.9, Mark 5 17068A 90564-08005-
Shim, T=1.1, Mark 6 17068A 90564-08006-
Stator Sub-Assy, Clutch (est $131.50) 17069 17069-16010-
Supercharger Assy 17620E 17620-16010-
(est $1873.75) Sub 17620-16011-
Union (Supercharger) 17065A 90406-06002-
Everything below here is not specified as 4AGZE thus presume is 4AGE
Gasket, Cylinder Head 11115 11115-16070-
Crankshaft and Pistons
Bearing, Connecting Rod, Mark 1 13041 13041-16070-01
Sub 13041-16071-01
Bearing, Connecting Rod, Mark 2 13041 13041-16070-02
Sub 13041-16071-02
Bearing, Connecting Rod, Mark 3 13041 13041-16070-03
Sub 13041-16071-03
Bearing, Crankshaft, Mark 1 11711 11701-16010-01
Bearing, Crankshaft, Mark 2 11711 11701-16010-02
Bearing, Crankshaft, Mark 3 11711 11701-16010-03
Bearing, Crankshaft, Mark 4 11711 11701-16010-04
Bearing, Crankshaft, Mark 5 11711 11701-16010-05
Bearing Set, Connecting Rod, U/S 0.25 13202 13204-16070-
Sub 13204-16071-
Bearing Set, Crankshaft, O/S 0.25 11702 11704-16010-
Bolt (Crankshaft Pulley Set) 13471C 90119-12127-
Bolt, Connecting Rod 13265 13265-16010-
Bolt, Flywheel Set 13405B 90105-10076-
Bush (Connecting Rod Small End) 13201A 90999-73111-
Crankshaft 13411 13401-16020-
Flywheel Sub-Assy 13405 13405-16050-
Gear, Flywheel Ring 13453 13453-10010-
Guide, Timing Belt 13566A 13566-15010-
Key (Crankshaft Timing Gear) 13521A 90280-05010-
Nut, Hexagon (Connecting Rod Bolt) 13265A 90170-09003-
Pin, Straight, L=18, OD=8 (Flywheel) 13405A 90250-08120-
Piston Sub-Assy, w/ Pin, Std, Mark 1 13101 13101-16100-01
Piston Sub-Assy, w/ Pin, Std, Mark 2 13101 13101-16100-02
Piston Sub-Assy, w/ Pin, Std, Mark 3 13101 13101-16100-03
Piston Sub-Assy, w/ Pin, O/S 0.50 13101 13103-16100-
Pulley, Crankshaft 13471 13470-16040-
Pulley, Crankshaft Timing 13521P 13521-16010-
Ring Set, Piston, Std 13011 13011-16090-
Ring Set, Piston, O/S 0.50 13011 13013-16090-
Ring, Hole Snap (Piston Pin) 13101A 90521-23005-
Rod Sub-Assy, Connecting 13201 13201-19095-
Sub 13201-19096-
Washer Set, Crankshaft Thrust, Std 11011 11011-15010-
Sub 11011-15020-
Thanks parrot.
if anyone wants a VIN for an AE92 GTZ Levin (map sensored 4AGZE) let me know.. i have the mod plate lying around home somewhere from the half cut.. that way you can give any toyota dealer the VIN, and they can match it to a part.. ie 4AGZE pistons 8.9CR..
