if you get one from an AE82 bigport will be identicle..
smallport will bolt on.. but may have different plug on TPS
gday
just worked out that my throttle body of my rwd big port is stuffed.
my question is: is there a difference between the rwd and fwd throttle bodies, and between big port and small ports?
also if anyone has got one to suit this application with a throttle position sensor, send me a pm, as i really need one.
thanks brad
they are different, the crankcase breather is on opposide sides, you can use FWD on RWD and vice versa, just need to sort out a few things.
as above, the breather bypass is differant. the gallery is still there, you just have to drill an extra hole in the tb in front of the butterfly.
78's
ok sounds good, now just got to find one,
thanks alot
