Hey guys,
The wheel alignment on my sprinter seems to be stuffed. I've had it lowered on King Springs, but no other mods. The Lower control arm bushes, castor rod bushes have been recently replaced with Peddars polyurathane bushes, and the ball joints are also new.
This was done 3 months ago, and the castor settings were set to about +3deg on both sides. After about a month, the car started pulling right and the steering was heavier turning one way. I had the alignment re-done 3 days ago and the told me that the castor was +4deg on one side and +2deg on the other. The steering wheel also shimmeys when under brakes as well.
I haven't hit anything, gutters etc. and apparently there is no damage to the castor rods. I thought that replacing bushes would stop the alignment going out every month or so, but this has not helped. Wheel bearings were replced about a year ago too. The steering rack has also been rebuilt.
What else needs to be done? Anyone else have these problems? Any suggestions/pointer appreciated.
Cheers,
Lok19.
