Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Tyre sizes for 15 x 7 ?
    Oldschool Member
    Aug 2006
    Hi
    i have a pretty stock adm 86, she needs new tyres soon so im gonna get new wheels as well (konig rewinds)
    just wondering if anyone knows whats the max tyre size i can get with 15 x 7 rims before i have to roll my guards?
    i have tried the search function but not much help
    Thanks - ...
    Albert
    Ian
    NOR
    id go for some 195/50's or 195/55
    or 205/50 if you want a little bit more width
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I've got 195/50's on mine.
    Oldschool Member
    Aug 2006
    Dish and uve had no problems with tyre mashing ?
    i should of mentioned i have coilovers if that makes any difference
    thanks for the help
    Ferny Grove
    tyre mashing?!?!?!?
    195/50's will be fine, from memory the rewinds are a zero offset 7 inch rim, so at most you will have to roll your guards (fold the lip under, no big deal)
    depends what height you run your car at really
    get 195/50's on them, fit them and see what happens, it won't be hard to solve any rubbing issues as they should only be slight.
    Oldschool Member
    Aug 2006
    thanks gilly, will do
    KAWAII_hachi_roku
    i have 185 pirellies and it is a great tires. but the choice is yours.
    Stefan
    Parkinson
    what about going 225's x 50 or is that too big?
    dont bother going with wider than 195x50 they stretch on the rim and reduce sidewall flex!
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    185/60 is a good size on a budget, as increased sidewall height makes up for the reduced width, so less sidewall flex. can be picked up cheaper than lower profile tires, too, cause they're pretty taxi spec.
  1. TYRE SIZES
    By chapl in forum Technical - Articles
    Last Post: 13th April 2008, 03:24 PM
  2. Rim Sizes + Tyre Profiles
    By driftke70 in forum Technical - Questions
    Last Post: 25th January 2006, 12:48 AM
