Results 1 to 10 of 11
Thread: what top hose to use
    JP
    Eastside
    Hey guys
    as u know im currently in the process of 4A-C to 4A-GE conversion im using the 4a-c external thermostat housing setup and trying to find out what top hoses fit? i've got a pic if it helps
    cheers jace
    Dec 2005
    Edit - That wont work .. nevermind.
    JP
    Eastside
    what u mean?
    Ferny Grove
    repco/supercheap universal multi fit hose. they bend however you want and work fine.
    Adam
    New South Wales
    How does the AE71 hose fit??
    JP
    Eastside
    hey guys
    used that multi fit hose from repco>< it leaks from the top and bottom, even with the hose clamps on to the tighest. I even snapped 1 hose clamp lol. Can anyone suggest a hose that will fit without cutting it?
    jace
    Will
    i looked 4AGES (get it, lol) and couldn;t find anything close to what i needed, so i did what everyone does and used two bends joined in the middle with lots of hose clamps. works fine, leaks a tiny bit but most of my coolant lines do.
    Senior Member mrbigport's Avatar
    Craig
    Canungra
    haha!.. ok i will do!..
    EDIT : this is meant to be DRIF86S post!
    4agte KE70 263.6whp
    QR Sprint Circuit 1:02.9
    QR Sprint Circuit 60.7 (turbo)
    QR Clubman Circuit 1:06.41 (first outing NA)
    QR Clubman Circuit 1:02.77 (turbo)
    http://www.ae86drivingclub.com.au/fo...ustom-Stickers
    full colour windscreen banners from $45!
    Nov 2005
    Leaking coolent lines???
    Use gasket sealer when attaching hoses, its oily and will help you put hoses on and when it dries you get no leaks
    Some ADM jap cars and most popular imports use smaller hose/inlet/outlet sizes then aussie cars, did you pick up the right size?
    I had that problem when doing my lines
    also, it looks like thats a similar position that your housing would have been in the 4ac, why cant you just use that hose or get a brand new one of the same type?
    Make up a pipe that fits out of some old bends and straight pipe sections all hose clamped together. Then when you get keen take this down to Repco/Bursons/wehrever and find a rad hose from another car that matches.
  1. Replies: 2
    Last Post: 14th April 2011, 11:33 PM
  2. Wanted. 4age top hose outer from the block to the radiator
    By porter in forum Cars or Parts Wanted
    Last Post: 30th March 2011, 12:29 AM
  3. WTB 4age Fwd Top Water Outlet (head To Rad Hose), QLD - Brisbane
    By Trev084 in forum Cars or Parts Wanted
    Last Post: 31st July 2010, 03:00 AM
  4. Jdm 4ag Into Ae71 With Ae71 Radiator, Which Top Hose
    By Trev084 in forum Technical - Questions
    Last Post: 1st April 2009, 03:40 PM
  5. wtb: top hose outlet
    By H8CHIR6KU in forum Cars or Parts Wanted
    Last Post: 28th February 2009, 05:18 PM
