as the topic says.... what other gearboxes has anyone used other than the w5* series boxes, i've heard of RX7 boxes being used but not to sure...
I beleive some of the clubman guys use a sierra box
Anything can be used. Just need an adaptor for the bellhousing, the right spigot bearing and maybe some playing with the clutch.
T50 = easy
W5* = "common" and parts are available for it
Anything else = custom, pain in the arse
Yeah what Hen said!
if it's NA, bolt a T50 to it.
Else, W55/6/7/8 boxes have off the shelf Bellhousings (Dellows, niteparts, etc.) for a decent cost.
Some people have put the J160 - the Altezza 6-speed and it's variants (as found in the MX5, RX8, S15 200SX) behind 4AGEs, but it's not an easy path and quite extensive fabrication & engineering skills are required to do so. The results however are very positive.
Unless you are converting to 4WD or a rear mount transaxle a'la Formula Atlantic - most other boxes would be a waste of time money and effort, especially something like an RX7 box - which the rotary guys bin and put W58's behind their big HP 13Bs....
how much heavier is the w series boxes???
T50 - 25.5Kg
W58 - 35Kg
Are you having problems with your W58?
S15 6 speed to suit 4A on jap auctions, bloody expensive.
JI60's from RX8's and such arent designed for huge torque loads either really.... i know, i rebuilt 1 for an RX8.... done like 50000km and syncro rings werent in good shape, and main bearings were noisy.
the reason i asked is cos i'm building a gze and wanted 2 find out if there were any cheaper alternatives to going to a supra box...
From Medicine_man.
some of the 5spd K series box bolt up.
sorry for a piece of useless info lol
Cheers Kieran
Thanks to: Az & me - Azcustom
John - Davidson Autobody
Matt - Tasmanian Engine Reconditioning
Tobias - Koolstik Signs
4AGTE Powerd AE86 Tassie Spec Build Thread
