has anyone run 15x8 -4 offset at the front? or close to 15x8 with neg offset?
Yep 15 by 8 neg 9s
yeah, 15 x 8 -4.........
Are you wondering about guard issues?![]()
super lights ey?
yeh i run 15*8 neg 9 offset with 195/50 tyres and its pretty low just needed noltec strut tops to pull the neg camber in to 2deg so the top of the tyre doesnt touch the guard and i pulled the caster foward to 3deg20min so it doesnt rub on the back of the wheel arch on near full lock so now they completly clear the guards and i also cut the plastic rib at the front outer edge of the inner guard and put mushroom head bolts in the top two outer holes where the inner guard is attached if that makes sense
i've got a set on the way. i have s13 coilies (extra track) had to flare guards to get 7.5 0 ssr's under at 2* camber. i'm going to have to run more camber to get the rims under but should be alright.
at the rear i have to raise the height about an inch and bash the guards out a little.
yea is hoping not to mod the guards
and yea 8spoke superlights
depending on how high your car is
mine has massive, i mean the biggest you can possible get guards and the tyres still scrub. its only an inch from the bumpstops tho.
for the fronts, u need camber or a really well setup suspension system
yea i got the 15x7 +12 at the front
prefect fit
tho would need more track and camber it seems
