ok. i sort of know, but the dodgy kent that did the conversion before i bought it made an abortion of the wiring. now im trying to fix it up and need some help with where the wires should come and go to.
this is the fuse box in question. its on the +ve terminal
the fuses are 80a on far left and 40 in the middle. the right one has a wiring going out, but nothing coming in.
i assume the 80a comes from the B+?
this is the wiring on the back of the box. the two white wires on the left side come from the same place. they go from one wire into two. i think they go to the B+ as one goes into the 80a.
the third white wire from the left comes out of the 40a and splits into two. one of these goes to the three wire plug on the back of the alternator (for voltage sense i think)
the other wire goes into the body fuse box with the wire that comes from the 80a and also goes into the body fues box.
does this look ok to others that have done the conversion? i think i will replace the fuse and put new wiring there.
