Results 1 to 10 of 20
Thread: Changing Diff
    Oct 2006
    Ive read a few posts and looked at a couple of articles and just want to know one thing;
    I have a totally stock ADM toyota sprinter. Using the standard rear end can i take the standard diff out and just replace it with an aftermarket diff(eg: TRD/KAAZ 2way), or do i have to replace the entire rear end? (axles, diff, tailshaft,brakes, etc)
    Thanks for your time.
    Oldschool Member
    Jun 2005
    If you wanna get a lsd of any description you need an entire t series rear end to go into your sprinter. Do a search on here, your likely to find them in t 18 which are rear now days or you could get them out of a te27 or old skool L2000 celica however with some of these rear ends you might need someone with a jig to cut and weld all your spring perches, swaybar mounts and trailing arms.
    leandro
    Ferny Grove
    read this
    Oldschool Member
    Jun 2005
    ^^^LOVE IT GILLY !!!
    someone should stick that
    leandro
    Oct 2006
    Thanks for the response guys.
    I also heard that some toyota hilux rear ends can be used to. Is that correct? Are they the T-18 or another one?
    Andrew
    East Melbourne
    T-18 is the model of car that has the T series diff (along with the JDM 86). The Hilux one is a F series?? and from the top of my head needs custom mounts.
    note that the t-18 version of the t series diff only came with drums, and only the 2nd series of t-18 came with mounts for the swaybar.
    Brad
    Central coast
    a T-18 diff is the only diff upgrade that will be a direct bolt in job.
    hilux celica ect will need new mounts welded onto it.
    Hilux = G series
    F series = Crown, some Tarago, some Supras, some other early stuff
    T18 or JDM T series are the only easy swaps, all others need mounts changed. A PITA if you can weld, expensive if you can't.
    Oct 2006
    Alright then it looks like im getting a T-series rear end then. So idealy id want a t-50, but t-18 will also do the job. Thanks for your help everyone.
    Brad
    Central coast
    T-50 is a gearbox. you want a T-18 diff, and rear half of the tailshaft.
  1. Changing the Carby!
    By x744 in forum Technical - Questions
    Last Post: 15th June 2012, 09:32 PM
  2. step-by-step guide: changing diff centres
    By Dave in forum Technical - Questions
    Last Post: 7th December 2009, 01:28 AM
  3. changing difs!
    By VTAZ! in forum Technical - Questions
    Last Post: 20th May 2009, 10:13 PM
