BUMP![]()
Anybody that could help me with the THROTTLE POSITION, HI-THROTTLE & LOW-THROTTLE settings ?
I have Kamakazee cams 262 degrees 8.9mm lift with T3 adj cam gears and PACESETTER 4-1 header installed...
Thanks in advance !!!![]()
BUMP![]()
Take it to a professional tuner. Different cars = different tunes
Can have bad consequences if done wrong
anybody anyhelp ???
hey mate, i just dug up my safc2 on paper
pretty sure this is may relate but here goes
Lo Throttle Hi Throttle
-34 1500 -17
-27 2500 -19
-35 3500 -26
-26 4500 -19
-17 5500 -17
-13 6000 -16
-9 7000 -14
-5 7500 -14
hope that helps
it's really helpful my friend !!!
How about the values at THROTTLE POSITION for HI & LO ?
i put the settings for hi&lo
as in the previous post, its just a base that u can work with may vary since u got mods on your engine
I mean the values for HI-THROTTLE POSITION (eg 70%) and LO-THROTTLE POSITION (eg 30%).
What was yours ?
Thanks a lot again ...
hey i cant get 1500 etc.. i can only get 1200 1400 1600...
i need the settings can any1 help???
