The mr2 gets crazy fuel consumption. Im suprised how little it uses.
I went to fill up my car last night, the car has done 330kms since the 4AC -> ZE engine conversion. I put in 25 litres and it was full(over flowing full). So the car only uses 1litre for every 13.2kms that better than what my 4ac used to do. I honestly thought it would use alot more that then that. Yes I do boosted it at every oppotunity, as you do.
So the fuel economy like in your ge / ze?
i get bout 9L per 100km with my basically stock 4A-GE sprinter.... not bad at all for a 23 year old car
400kms to a tank in the 20v
leaking fuel tank so i probably lose 10 litres but around 400kms to a tank so around 10l/100km
I got mine emission tested few months back (smallport 4age running gze head and electrics .. plus turbo at 4psi)
Surprisingly feul consumption was be 7.9L per 100km .
The fuel consumption is an unexpected suprise. Before the conversion I thought I probably have to put extra money aside for fuel. Just calculated per 100ks mine does about 7.58litres/100![]()
Bigport 4age - Flat Top Pistons, Larger Injectors - 250L = 280 - 300Kms
My mates 20v gets around 600Kms + to a full tank...![]()
Big port 4age, 3.7 diff gets around 7.5l/100km.
i get 400km per 40l tank when im thrashing it well not as much! also running 4.11 ratio locker
JAPANESE DOMESTIC MARKET AS F*CK!!! hmmm, when you prenounce it properly, it sounds gayhow bout that.
