Results 1 to 10 of 10
Thread: What radiator do u aftermarketer's run?
    Sep 2006
    hey iv been looking threw members ride's n trying to see what radiator people with conversion's are running. like if they use cross flowed or just the same side in + out (which sucks) sorry if its been asked b4!
    Rob
    Moorabbin
    i used an st162 radiator, not really cross flow
    i definitely didnt suck
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    Custom RMS radiator... Has been donated to me..
    Oldschool Member
    Apr 2005
    Qld
    I too run an ST182 Radiator. Twin core, Twin thermo fans. Runs a CA18DET at 85 deg all day everyday.
    Joel
    Blackwood
    I'll be using an S13 SR20 radiator in my sprinter for a 4AGTE.
    Another good rad for a 4AC/4AGE is a manual hyundai excel 95-2000 (i think model).
    For a KE70 running a 4K-C, a good rad to use is an AE82 rad.
    AE86 4AGE "Slowly but surely"
    Veteran driftism's Avatar
    Andrew
    Watsoia
    there's an old camry model... a vzv10 or something which has a twin core rad, that is almost identical to a sprinter radiator... if i had more money that's what i'd be using
    parrot
    Leigh
    Penshurst
    I used an old Camry Radiator that was sitting at my mates workshop
    Not sure what model it was from but it was a 2.2 auto pretty much the same height as the ae86 but it was a bit wider it's cross flow and has thermo fans on it one of them is on a switch.
    I had to make up a return pipe out of aluminium which Hypertune generously donated to me:-)
    I got it going for 30 bucks for relays wiring switch etc and the radiator cost me a case of beer.
    Leigh
    Tom
    SOR
    I run a twin core Ae86 radiator my mechanic got for me from Japan. Everything exactly the same as stock except for twin core. No problem so far with my ze.
    Sep 2006
    im running a 20v atm, so ST182 would do fine with one thermo?, i was also gonan try the dato 1600 radiators.. i think there crossflow 3 core.. i think! but i dunno about the whole cross flow situation..
  1. Replies: 3
    Last Post: 11th June 2012, 08:22 PM
  2. Replies: 2
    Last Post: 9th March 2011, 03:41 AM
  3. lookin for twin thermo's to suit standard 86 radiator
    By TRD_86 in forum Technical - Questions
    Last Post: 4th August 2008, 11:25 AM
  4. what's the widest 15'' semi-slick have you run on??
    By DK86 in forum Technical - Questions
    Last Post: 26th July 2007, 06:48 PM
  5. 4age wont run on other ecu's
    By mikes86 in forum Technical - Questions
    Last Post: 7th July 2005, 10:23 AM
