thats happens to all stuts, use a rattle gun and you will right
recently (read yesterday) aquired S13 coilovers...
Now I want to remove the camber tops and replace them with the T3 ones I have...
but I cant remove the nut that holds the shock in place.. as everything just spins when I turn it... if the coilovers were installed and the strut bolts were in the holes then it might be different... but the shock itself seems to just spin as well...
I dont have a vice or anything to hold them so its kinda difficult to remove the nuts...
any ideas..
Niz.........
dont got one of them either lol.......... the thing is though you cant hold onto the shockie to stop it turning when you try and loosen the nut, as the spring is in the way...
no other means bar a rattle gun...unless u want to get messy and potentially fuck shit up
when i removed mine, i jsut got some multi grips and attached them super tight to the plate thing on the top, and somehow wedged it so it couldnt turn, was a bit of a bugger to do, but worked
- Blaise Pascal
I see I see....
Inventive wedging or rattle gun. I ended up buying a compressor etc. and have just come in from getting one off that I couldn't budge. Don't be tempted to grip the piston. If your springs are too short to hold the top plate in plece, there isn't any option. Take the strut down to a garage with the right socket and ask nicely.
yeh that was what I was thinking of doing... get ol mate around the corner to fix me up....
yep rattle gun.
i still got those calipers, work is crazy right now so i'm not having much time to get over your way... i'll pm you later
no worries man.......![]()
