Results 1 to 10 of 10
Thread: suspension setup
    whats the best springs for a circuit car? 6kg rear 8kg front is whats generally suggested for drift but I want a basic setup that will give me more corner speed. thanks
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    circuit setup and drift setup are not that dissimilar than each other, wouldnt be able to tell u exact kg's
    have a look at TRD spring rates i think u'll find there 8 front and 6 rear, and they were probably made for street and track.
    also on another note, drifters started out using the stiff-est springs (and huge neg camber) they could, but eventually went softer (and less camber).
    Elite rthy's Avatar
    Leo
    Tulla
    buy it and try it
    Will
    start with 6 kg front and 4.5 rear, then go from there.
    Elite rthy's Avatar
    Leo
    Tulla
    I think 6 at the front is ok but 4.5 is too much and would cause too much oversteer, Normally people fit 6/4. Same with 8/6 too higher rate on the rear I think. Where do you plan to drive this thing?
    Rob
    Moorabbin
    trd recommend 6 and 4.7, i sell the 6 and 4.5
    i think you are just paranoid of oversteer sam!
    my car with 8 and 6 was very neutral
    Oldschool Member
    Apr 2005
    I find 8 and 6 too hard for street tyres. Well not tooo hard, but you could get much more rear end grip with somthing like 3-4kg in the back.
    8-6 is about on the money for semi's though.
    Elite rthy's Avatar
    Leo
    Tulla
    Yeah I dont know dave, I tried a few different setups and I now run 4.9kg fronts and roughly 3.3kg rear, seems to be pretty close to neutral now. Using the same ratio it works out to 6:4
    I tottaly agree with monkeymajik on the hardness settings
    i plan to drive it on street and track SAM
    Im think ill go 8kg front and 4kg rear.
  1. Your Suspension Setup
    By sonsta in forum Technical - Articles
    Last Post: 30th April 2014, 01:39 PM
  2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  3. Suspension setup for Drift....
    By baumyone in forum Technical - Questions
    Last Post: 19th December 2010, 07:03 PM
  4. Need Help With Suspension Setup
    By ArbPotatoes in forum Technical - Questions
    Last Post: 30th June 2009, 10:51 PM
